Open
Active Period: add enabled/disabled status
Related products:FME Flow
  • Feb 28, 2024 9:14 AM UTC
  • 0 replies
  • 51 views
jmiddel
Hi, in FME Flow 2023.2.1 you can´t disable an Active Period once it was successfully created. If you like to disable an Active period but keep the configuration (like a repeat on interval config), you need to remove it or adjust the start/end date.
It would be more helpful to enable/disable an Active Period like it is done in the Job Routing / Engine Assignment rule / Schedule / Automation.
