Open
Actions - Remove
Related products:FME Flow
vxn43
Forum|alt.badge.img+20
Whenever Actions - Remove is done on a Schedule, Resource, Repository, etc... the box next to the, for example, Resource that you want to remove is at first checked, then the checkmark disappears when you do Actions - Remove; it would be more reassuring to the FME Flow users to keep the check mark in the box to left of whatever is to be removed, rather than have the check mark disappear once dialog box for Actions - Remove appears.
