Archived
Ability to set the standard Geometry Parameter base map to personal preference.
  • August 22, 2023
  • 95 views
sd1201
Participant
The base map within the geometry parameter is set to an Open Streets base map. If this is not the base map you would like to use, you would need to change this map every time you want to use this parameter. I would like the ability to set the base map within the geometry parameter to one of my choosing and for that base map to be set within that parameter.
LizAtSafe
Forum|alt.badge.img+15
  • February 10, 2024
Updated idea statusGathering InterestArchived
Idea merged into:
All the votes from this idea have been transferred.
