Open
A transformer, which combines AttributeValueMapper, AttributeRangeMapper and TestFilter
Related products:Transformers
  • October 29, 2018
  • 78 views
geolassi
Forum|alt.badge.img+8
***Note from Migration:***
Original Title was: A transformer, which combines AttributeValueMapper, AttributeRangeMapper and TestFilter
I'm using AttributeValueMapper, AttributeRangeMapper and TestFilter quite a lot, but I'm missing a transformer, which would have similar interface as AttributeValueMapper, but you could set a Test Condition to the source value like in TestFilter. If the value of the source attribute passes the test condition, the destination attribute would get the value from the corresponding Destination Value.
At the moment I usually have a TestFilter with AttributeCreators for each output port of the TestFilter. AttributeValueMapper is a good tool, but lacks the capabilities of TestFilter.
Of course I could use Conditional Values in e.g. AttributeManager, but they're always hidden inside the transformer.
andreaatsafe
Forum|alt.badge.img+17
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
