Archived
A Quick Option to Flip the Order of Requestor and Supplier on a FeatureMerger
Related products:Transformers
  • October 29, 2015
  • 28 views
Forum|alt.badge.img+3
A quick option to flip the order of requestor and supplier on a FeatureMerger. I often connect and set up the join attributes before realizing my supplier should have been the requestor, or the other way around. It's a bit cumbersome having to both reconnect the incoming lines to the ports + changing the join attributes.
samisnunu
Forum|alt.badge.img+15
  • March 7, 2021
I agree, I suffer the same always if I need to change the connections of Supplier versus Requester, you have to update both join key attributes from the their drip down list, a bit annoying.. I guess we need a small button [Flip Direction] or [Swap Direction] next to the keys row..
