Archived
A DropFeatureCache tranformer
Related products:FME Form
  • April 16, 2025
  • 12 replies
  • 424 views
ronnie.utter
Forum|alt.badge.img+11
In large and complex FME workspaces, memory usage can become a major performance bottleneck, especially when feature caching is enabled for debugging or when large feature streams are processed sequentially.
It would be incredibly useful to have a dedicated transformer (e.g., DropFeatureCache, ClearMemory, or similar) that can be placed mid-flow to explicitly clear cached data, or release memory from earlier processing paths.
This would be especially helpful in long chains of transformations, loops, or branching logic where intermediate data is no longer needed but still retained in memory.
JennaKAtSafe
Forum|alt.badge.img+9
New→Gathering Interest
JennaKAtSafe
Hi ​@ronnie.utter, thanks for raising this pain point. We’re working on some exciting changes to how Feature Caching works. While it may not take the form of a dedicated transformer like the ones you’ve suggested, I believe it will help alleviate some of the concerns around heavy memory usage.
ronnie.utter
  • April 17, 2025
Thank you for your answer. Looking forward to review the development ☀️
ronnie.utter
  • April 17, 2025
​@JennaKAtSafe ,One thought I also have is this: Is it true that unused output ports, such as in the FeatureMerger, still store cache or use memory? If so, would a function like enabe a "Clear data from unused ports" option in the transformer help? Could this be a good setting to use?
JennaKAtSafe
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
JennaKAtSafe
JennaKAtSafe
​@ronnie.utter Yes, I can confirm that currently, feature caching occurs for disconnected ports and will take time during workspace execution, as it writes files to disk. However, this doesn’t necessarily increase the process’s memory usage, since each feature cache acts as an on-disk terminus — meaning the features don’t need to be held in memory beyond that point.
agelfert
Forum|alt.badge.img+8
  • July 17, 2025
I’m so glad this is already out there as an idea. Was about to suggest it otherwise.
I rely on caching a lot when troubleshooting or developing transformation pipelines. But when you get into the millions of records and those get cached in FME_TEMP, I fill up a lot of disk space. Switching off caching for portions of my workspace that have already been tested or that I’m currently not interested in would be a huge enhancement.
LizAtSafe
Forum|alt.badge.img+25
  • May 19, 2026
Gathering Interest→Open
JennaKAtSafe
Updated idea statusOpen→Archived
JennaKAtSafe
Hi ​@ronnie.utter, I am archiving this Idea given that a dedicated transformer won’t be the solution. I have captured this pain point as part of an existing request. [IDEA-36] For internal reference
Caching is an area we care about a lot and you will hear more when this improvement happens!
vlroyrenn
Forum|alt.badge.img+14
  • June 3, 2026
It’s obvious that this feature couldn’t be implemented as a “regular” transformer, given how it affects the behavior of the rest of the workbench in ways that break out of what any other transformer have ever been able to do. There’s also the whole notion of what to do with paths that don’t connect to the cache-clearing nodes, which you can’t really do with a transformer.
If I had to guess what IDEA-36 is about, I would have to guess that it tries integrating this suggestion into bookmarks instead of transformers.
As of right now, on FME, any node inside a bookmark that was collapsed when the run started will not cache any features on any of its ports unless it connects to a transformer outside that bookmark. Unlike transformers, this has the benefit of putting boundaries on both sides of the “cache fences”, so most likely we’ll be seeing a special bookmark mode that clears feature cache for the transformers within itself once all of its output ports have closed.
