Open
Auto-import Layers for ArcGIS Portal/Online Writers if using existing feature service
Related products:Integrations
danilo_fme
mgg_beca
raghavendrans
  • danilo_fme
    danilo_fme
  • mgg_beca
    mgg_beca
  • raghavendrans
    raghavendrans
mgg_beca
Hi there,
In ArcGIS Online/Portal if you are writing to a feature service, and that feature service already exists, then almost always you want to write to an existing layer.  However the current workflow is:
  • Add writer
  • Add bogus feature type
  • Import Feature type from existing layers
  • Delete bogus feature type
I feel like this could be optimised.  When you add a Portal/Agol Writer, and you choose an existing feature service, you should be prompted to select from the existing layers from that feature service.
This would be a great quality of life update for people that write to Esri Web Layers often.
Thanks,
Marc
Forum|alt.badge.img+39
  • May 12, 2025
This is already possible in the standard writer, but not in the FeatureWriter (i think)
mgg_beca
Forum|alt.badge.img+11
  • May 12, 2025
Ohkay then, I’m a dummy.
Just looked at the featurewriter, and found that same “Import from Dataset” option here:
But then you have to go through the whole portal sign in process again:
I feel like this process could be streamlined, both for the regular writer and the FeatureWriter transformer.
  • May 13, 2025
Import from Dataset on the writer picks up the portal connection details from the writer for me. I'll see if it's different the feature writer
NickAtSafe
Forum|alt.badge.img+4
  • May 21, 2025
NewOpen
