Open
SQL database in Microsoft Fabric - Entra Authentication
Related products:Integrations
danilo_fme
jdandriessen
raghavendrans
maarten_wsrl
arenscott
+2
  • danilo_fme
    danilo_fme
  • jdandriessen
    jdandriessen
  • raghavendrans
    raghavendrans
  • maarten_wsrl
    maarten_wsrl
  • arenscott
    arenscott
  • wouterdusardo
    wouterdusardo
  • arodriguez
    arodriguez
oliver.morris
SQL database in Microsoft Fabric is now in preview, we would like to be able to read/write to it with FME. Only Microsoft Entra Auth is supported - https://learn.microsoft.com/en-us/fabric/database/sql/connect
Please can the sql server readers/writers be updated to support this type of authentication.
PierreAtSafe
NewOpen
PierreAtSafe
Hi ​@oliver.morris,
I’m doing some research on potential development on the Microsoft Fabric front. Would you be able to give me more information on the use cases you have with the Fabric ecosystem? I acknowledge the need to have a connector for MS SQL Database in Fabric. Would there be other important use cases you’d have?
Thank you
oliver.morris
Forum|alt.badge.img+12
  • June 11, 2025
@PierreAtSafe Entra is a requirement to connect to the SQL Database contained within the Fabric platform, it seems increasingly this authentication route is being adopted by microsoft so it would be great to have this authentication mechanism.
It would be great to have read/write to the Data Lake as well, I know this is more tricky - perhaps via DuckDB?
PierreAtSafe
@oliver.morris got it for Entra ID! On the authentication front, are you also using Service Principals by any chance?
Regarding the data lake, you mean accessing OneLake in Fabric right?
