Released
Reading IFC files less sensitive on numbers
Related products:Integrations
  • January 21, 2025
  • 15 views
danilo_fme
  • danilo_fme
    danilo_fme
mariaka
Issue
Some IFC files cannot be read:
ISO10303-21: Skipping instance #743204: Instance  is not syntactically valid.
Workaround
The relevant lines can be changed in a text editor, e.g. from
#743204=IFCCARTESIANPOINT((0.,0.,520)); to #743204=IFCCARTESIANPOINT((0.,0.,520.));
The IFC files are in fact syntactically valid. Other software and validations do not throw errors on that issue.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
andreaatsafe
Forum|alt.badge.img+12
In FME 2025.0 and newer, we have a new IFC Reader (short name: IFC_API) which is more flexible with syntax.
For missing decimal places, the new reader should be able to handle this.
Try it out!
andreaatsafe
NewReleased
