Open
Single-View Attribute Transformer
Related products:Transformers
danilo_fme
dustin
  • danilo_fme
    danilo_fme
  • dustin
    dustin
danii
It would be beneficial to have a transformer that displays all attribute values simultaneously, rather than using the TestFilter Transformer. In some cases, I need to process each value, which can be time-consuming when using TestFilter to have each attribute value on its own tab.
Forum|alt.badge.img+50
Have you tried the AttributeFilter transformer? If you import the unique values from the source dataset or the feature cache it saves you a lot of work.
danii
Forum|alt.badge.img+13
  • June 17, 2024
@redgeographics Thanks for the tips! However, I still believe it would be beneficial to have an own transformer to display attribute values without the need to import them. Just connect the transformer, and voilà, the attributes appear. 😉😉
LizAtSafe
Forum|alt.badge.img+15
  • September 23, 2024
NewOpen
