Open
Add support for File Upload in FME Flow Automation Apps
Related products:FME Flow
marnickcle
When you add a "file" manual key to an automation which get run by an automation app, the option is to choose a file already in the resources of FME Flow. It would be nice to have an option for a user to upload a file like what's already available in workspace apps. For a User Parameter "File" the user is able to upload a file which gets used by the workspace the workspace app runs. The same would be ideal for automation apps.
asprague
  • December 10, 2024
I'm surprised this hasn't been implemented already. It seems like it would be straight forward. Is there any workaround that allows us to upload a .shp file into a user parameter within a custom attribute in the fme automations?
tino
Forum|alt.badge.img+16
  • March 19, 2025
I also stumbled just over this very weird limitation. After i added a manual Trigger to the automation, you can add a manual parameter of type “Choose File”.
This even already provides a UI for file selection in a Flow Automation App. But after struggeling with assigning Access rights to the app token to the File Upload Service and some Resource folders, i noticed that this manual file selection is only able to select a already existing file (and this is also stated in the doc).
I do not see any reason, why at this point the temporary file upload like with a Workspace App with file input should not be possible.
