The order in which features are read play an important part in the performance or simplicity of a workspace. Reader order can be specified by changing the order in the Navigator. Creators only have two options: read at start or read at end. I feel better control concerning Reader/Creator order would be a great improvement.
This idea has been mentioned before by @david_r and @takashi here (though I couldn't find the idea mentioned in his last reply) and by @fmelizard here. Apparently this call has been logged with Safe already, but perhaps we can gather some votes or ideas on how it should work on this post.
Some possibilities:
- Creators also showing up in the Navigator inbetween the readers. Simple and uses existing functionality to determine order.
- A seperate window to rearrange all Creators/Readers in one go. Seems a bit clunky.
- An option on a Creator to 'Read [before/after] [Reader/Creator] X. Quite simple, but not deterministic if you schedule two Creators to run after the same Reader.
