Released
Tableau .hyper Writer
Related products:FME Form
brianatsafe
siennaatsafe
nathanatsafe
fmelizard
tim_wood
+7
  • brianatsafe
    brianatsafe
  • siennaatsafe
    siennaatsafe
  • nathanatsafe
    nathanatsafe
  • fmelizard
    fmelizard
  • tim_wood
    tim_wood
  • helmoet
    helmoet
  • patlougheed
    patlougheed
  • andrew1
    andrew1
  • mariofederis
  • petri
    petri
  • zorawar
  • laurawatsafe
    laurawatsafe
Beginning in Tableau version v10.5 (January 2018), extracts use the .hyper format instead of the .tde format. Extracts in the .hyper format take advantage of an improved data engine, which supports the same fast analytical and query performance as the data engine before it, but for even larger extracts.
Suggest creating a writer for Tableau's new extract file format ".hyper".
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
Does anyone know if there's are plans for FME to add such writer?
helmoet
Forum|alt.badge.img+8
  • November 8, 2018
The more the better :-)
helmoet
  • January 2, 2019
Hi @david_r, you know if Safe is planning to implement the tableau .hyper format, or do you have experience on the .hyper format and FME?
  • January 3, 2019
Sorry, I have no idea, it's been a (relatively) long time since I used Tableau... Maybe consider contacting Safe support directly about their plans for this format. Maybe they know something that hasn't been signalled here.
helmoet
  • January 3, 2019
Ok, thanks. Support case number is C141882
steveatsafe
Forum|alt.badge.img+12
Tableau Hyper Writer is now available in 2020.1 as Tech Preview- https://www.safe.com/integrate/tableau-hyper/. Check it out and send us some feedback.
steveatsafe
Hi @mariofederis, @helmoet, @zorawar,
Check out - https://www.safe.com/integrate/tableau-hyper/
reedwhit
Forum|alt.badge.img+10
  • October 5, 2022
Thank you Safe for supporting Tableau... great tool that many of our clients are using. Let me ask this thread.... are there any plans for a hyper reader in FME? I find myself wanting to use this format in automated datasource extracts and to sync data using the Tableau platform and rest api. maybe there is an alternative Im not thinking of to query the hyper file with some other method.... @steveatsafe​ any tips will be appreciated.
steveatsafe
  • October 11, 2022
Hi @Reed Whittington​, there are no plans at this time but we do have this Format Request recorded in our system.
May I suggest you create an Idea for this to collect your interest (and possibly other community members).
I'm checking to see if there are any 'known' plans to implement this format.
