Archived
Add <thisAttributeName> as operator to Attribute transformers
Related products:Transformers
siennaatsafe
gbj1717
maryse_bucking
  • siennaatsafe
    siennaatsafe
  • gbj1717
    gbj1717
  • maryse_bucking
    maryse_bucking
maryse_bucking
Often I need to recalculate attributes based on its own values. Sometimes the fields are basically the same, and therefore the formula is the same. But because the AttributeFieldName is different, every time I copy the formula, I also need to adjust for the changing fieldname. Which can easily introduce errors, especially when you have a lot of fields.
Why not have an operator which specifies the value of the current field. That way in the AttributeManager would look something like:
FieldA conditional value
if <thisAttributeName> has a value then @Value(<thisAttributeName>)
else if 10<@Value(CheckField) then 'G'
else null
FieldB conditional value
else if 11<@Value(CheckField) then 'G'
else null
instead of:
if FieldA has a value then @Value(FieldA )
else null
if FieldB has a value then @Value(FieldB )
else null
Forum|alt.badge.img+39
  • March 10, 2021
This is already possible by using @CurrentAttribute()
LizAtSafe
Forum|alt.badge.img+15
  • April 5, 2025
OpenArchived
