erik_jan
Forum|alt.badge.img+18
  • January 20, 2017
And in addition to REGEX other functions like UPPER, LOWER, SUBSTRING, PADDING.
Forum|alt.badge.img+7
Great suggestion @erik_jan! I've updated the title.
geolassi
Forum|alt.badge.img+5
  • February 8, 2017
Excellent idea!
  • February 20, 2017
The key fields on FeatureMerger allow you to use the Text Editor where you have access to all these functions, as well as regex functions. IS this not sufficient?
@MarkAtSafe
I guess that is indeed sufficient for the string functions so I removed them from the suggestion.
I am struggling a bit with how to use regex since those functions require a string as input while I would like to use the string entered into the other input (requester / supplier) to be compared against.
