Open
3D Oriented Bounding Cube
Related products:Transformers
  • December 12, 2019
  • 62 views
Please add 3D Oriented Bounding Cube to BoundingBoxReplacer
lars_de_vries
Forum|alt.badge.img+10
Isn't it easy to create a custom transformer that uses a BoundingBoxExtractor to get the _zmin and _zmax. Next to use a BoundingBoxReplacer using the 2D Oriented Bounding Box and use an Offsetter and an Extuder to make it a 3D Oriented Bounding Cube?
Or do you also want it to be oriented around the other axis?
antoine
Forum|alt.badge.img+7
  • April 23, 2020
CGAL released a version of this kind of oriented bounding box, this would help a lot:
https://www.cgal.org/2020/04/20/Optimal_bounding_box/
