Add an option to the TimeStamper to create a global time stamp, similar as the counter creates a global count. Also add an option to create the timestamp attribute only once for the time of the first or last feature passing the transformer. This is relevant, for example, when fanning out on a filename with a timestamp where different timestamps on the filename result in separate files.
