The current web interface for managing resources does not allow for renaming files and folders. On FME Server you generally will have other access to the filesystem (at least an admin would have), but on FME Cloud this is not the case and renaming a file would mean removing it and re-uploading it under a different name. So an option to rename files and folders through the resources interface would be very useful.
