Open
Expose DWG Sheet Names via Schema Port in FeatureReader
Related products:Transformers
geomancer
danilo_fme
davtorgh
panda
kennyo
+5
  • geomancer
    geomancer
  • danilo_fme
    danilo_fme
  • davtorgh
    davtorgh
  • panda
    panda
  • kennyo
    kennyo
  • chriswilson
    chriswilson
  • dana
    dana
  • mmccart
    mmccart
  • geogaard
    geogaard
  • mark2atsafe
    mark2atsafe
mmccart
Add the ability to expose paper space sheet names via the Schema Port within the FeatureReader when reading AutoCAD DWG files. Currently, a solution suggested by @jedi121 (https://community.safe.com/s/question/0D54Q000080hBiUSAU/how-to-read-all-paper-spaces-from-acad-file) works well for the DWG Reader but does not expose all sheet names within the FeatureReader transformer.
Or can you add an option to read all DWG sheets in the AutoCAD DWG reader parameters vs. manually selecting them? Maybe add the option here:
I am attempting to read all sheet names for a DWG file using parameters within a FeatureReader.
Be the first to reply!
