Archived
Emailer Transformer: attachment could be optional when specified
Related products:Transformers
danilo_fme
  • danilo_fme
    danilo_fme
giosp
Now if you specify to attach a file in the Emailer the file is mandatory. It will be nice to specify if the attachment is mandatory or not. In some cases my attachment is not created in the procedure, for example an error log.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
  • June 4, 2019
Agreed. Emailer should provide a way to escape out of non-attachment features when they do not have one. A conditional setting (like available in other transformers) would be fine fix.
The work around I have been using is two identical transformers, and a tester for attachment having a value and routing accordingly.
stevenjh
Forum|alt.badge.img+5
  • May 31, 2022
Hard agree, I have a workflow that may or may not have 2 attachments, this is now 4 instances of the emailer!
I think a conditional step would work well.
