Archived
Pass attribute values to a parameter for use by other transformers/workspaces
Related products:Transformers
  • June 21, 2016
  • 1 view
danilo_fme
  • danilo_fme
    danilo_fme
jackyd
I recently wanted to use the maximum value of an attribute on one table as the start value of the counter on another table. To do this i have to calculate the value then use an attribute creator on each table and a feature merger to then calculate the new counter value
I would have been much neater and simpler if i could have passed the value to a parameter that the counter could use as the start value.
jdh
Forum|alt.badge.img+28
  • June 29, 2016
Have you considered using global variables?
