Archived
Connector properties Listed as Private Parameters so they can be referenced in W
Related products:Transformers
  • September 27, 2017
  • 0 replies
  • 0 views
siennaatsafe
fmelizard
danilo_fme
ecthelion
adrian_farrell
  • siennaatsafe
    siennaatsafe
  • fmelizard
    fmelizard
  • danilo_fme
    danilo_fme
  • ecthelion
    ecthelion
  • adrian_farrell
    adrian_farrell
fmelizard
***Note from Migration:***
Original Title was: Connector properties Listed as Private Parameters so they can be referenced in Workspace
It would be useful to have FME web or database connections parameters available as private parameters to the workspace similar to how FME Server properties are available. Use case is that when we are running in a DevOps environment where we try to automate promotion of work from DEV to TEST to PROD, we need to repoint web api calls to the instance URL described in the connection (HTTPCaller). In the case of Salesforce, base url for sandbox is test.salesforce.com while production is login.salesforce.com. Similarly for Maximo, AMANDA, Cityworks, SAP, and others.
