Open
Make it easier to work with JSON/XML result from REST Service call
Related products:Transformers
fmelizard
With REST web services, generally they return JSON/XML, which I then need to manipulate into attributes.
The pattern of work is often:
  1. Add Creator, HTTPCaller, Logger/Inspector
  2. Run workspace
  3. Inspect returned JSON/XML - determine if need to fragment and flatten or only flatten.
  4. Add JSONFragmenter or JSONFlattener or XML equivalent and Logger/Inspector.
  5. Run workspace.
  6. Inspect attributes created from flattening.
  7. Expose attribute names that were created by flattening.
I wish this was less work.
fmelizard
Forum|alt.badge.img+20
  • October 17, 2017
nickison
Forum|alt.badge.img+3
  • October 17, 2017
As someone who has done these steps every day for the past 6 months, yes please!
u12runm
Forum|alt.badge.img+4
  • February 22, 2024
I hate working with complex Json files… this process needs to be easier/more automated or more help.
