Released
Python-function to extract absolute path
Related products:FME Form
martinkoch
I use scripted parameters from a configuration-file, similar to explained in many blog-posts.
Te location of the script is passed through a public parameter of the type 'file(existing)'.
This parameter sometimes contains an absolute path, when the config-file is stored somewhere on the filesystem, but sometimes part of it is a FME parameter such as $(FME_MF_DIR) when the config-file is stored close to the workspace. Also, on server, I deliberately use a server-parameter such as $(FME_SHAREDRESOURCE_DATA).
To cope with this, I have had to hack a quite nasty looking bit of python
import fme import ConfigParser import os import re fmeParam = re.compile("A$(FME_[A-Z]+_[A-Z]+)") fmeParamName = re.compile("FME_[A-Z]+_[A-Z]+") def findAbsolutePath(fileParamName):     paramValue = fme.macroValues[fileParamName]     fmeParamList = fmeParam.findall(paramValue)     if fmeParamList != []:         fmeParamKey = fmeParamName.findall(fmeParamList[0])[0]         fmeBasePath = fme.macroValues[fmeParamKey]         relFilePath = fmeParam.split(paramValue)[1]         absFilePath = os.path.join(fmeBasePath,relFilePath)     else:         absFilePath = paramValue     return absFilePath filePath = findAbsolutePath("conffile") conf = ConfigParser.ConfigParser() conf.optionxform = lambda option: option conf.read(filePath) return conf.getint("Parameters","MyBeautifulNumber")
testing for the presence of FME-parameters, filtering out the key I need to get them from macroValues, and glueing it all together for an absolute path where I can find my config-file.
Could there be a function like fme.getAbsolutePath('[key_of_filepath-parameter]')?
Kind regards,
Martin
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
  • February 19, 2016
Hi
I'm not quite sure I'm understanding your use-case, but have you tried using something like:
myFile = fmeobjects.FMESession().decodeFromFMEParsableText('$(FME_MF_DIR)/test.txt')
It seems to work for me.
David
  • February 19, 2016
Hi
I've written the following two helper functions to accomplish exactly this:
import re
import os.path
def expand_fme_macros(input):
    # Expands all FME macro values in input string
    matches = re.findall("\$\((\w+)\)", input)
    for group in matches:
        input = input.replace("$(%s)" % group, FME_MacroValues[group])
    return input
def get_fully_qualified_path(input):
    # Expands input string into an absolute path
    input = os.path.abspath(expand_fme_macros(input))
    dir = os.path.dirname(input)
    if not dir:
        input = os.path.join(FME_MacroValues['FME_MF_DIR'], input)
    return os.path.abspath(input)
Use expand_fme_macros() for strings in general, and get_fully_qualified_path() for path and file names.
Usage, given that the parameter value "FME_MF_DIR" = "c:\my_data_dir\"
  • expand_fme_macros("The value of FME_MF_DIR is $(FME_MF_DIR)") returns "The value of FME_MF_DIR is c:\my_data_dir\"
  • get_fully_qualified_path("my_data.mdb") returns "c:\my_data_dir\my_data.mdb"
  • get_fully_qualified_path("temp\my_data.mdb") returns "c:\my_data_dir\temp\my_data.mdb"
  • get_fully_qualified_path("temp\..\my_data.mdb") returns "c:\my_data_dir\my_data.mdb"
  • get_fully_qualified_path("d:\another\dir\my_data.mdb") returns "d:\another\dir\my_data.mdb"
This works for any value found in FME_MacroValues, notably:
  • FME internal parameters, such as FME_MF_DIR, FME_JOB_ID, FME_DATA_REPOSITORY, FME_SERVER_NAME, etc.
  • Published parameters
  • Private parameters
Hope this helps.
David
martinkoch
Forum|alt.badge.img+18
  • February 19, 2016
Thanks, quite an elegant solution for replacing every parameter-like value surrounded by $( ). Will probably use your findall and .replace("$(%s)") to tidy-up at least the double reg-ex and list-indices in my code.
Still leaves the clear sign more people are dealing with this matter using regex-wizardry.
Makes me a bit uneasy, as there might be a real value which meets the regex, but is no FME-parameter, making the workspace barf at a "key not found" error or something alike when searching the fme.macroValue dictionary.
Would like Safe software to take that code-responsibility. Found the cause of this problem this afternoon, cooked up above code, but have to get used to it a little before I trust it in a high-load production environment.
Kind regards,
Martin
edit: Made my reply vegetarian by having 'values meet' in stead of 'meat'.
fmelizard
Forum|alt.badge.img+19
  • February 21, 2016
Feels like we should include @david_r 's functions in the Python FME API. I'll discuss with the appropriate authorities.
  • February 22, 2016
I agree that expand_fme_macros() could use some error checking:
        try:
        except:
            pass
    return input
This way it'll just silently ignore any unknown macros $(...)
David
fmelizard
  • February 22, 2016
The authorities like it. PR filed as 68362.
  • February 23, 2016
Perhaps I am missing something here, but when I run the following in a Startup Python Script:
print "The value of FME_MF_DIR is $(FME_MF_DIR)."
The output I get is:
The value of FME_MF_DIR is C:\\Users\\SWu\\AppData\\Local\\Temp/.
What build of FME is being run that doesn't auto-evaluate the $(FME_MF_DIR)?
Thanks,
Stephen
  • February 25, 2016
Yes, I've also noticed that, FME tries to be pretty clever about macros in hard coded strings in your code.
But if you read a string containing an FME macro from e.g. a configuration file, it does not get expanded automatically. That is a potential use case for the function above.
  • February 25, 2016
Thanks for the clarification David!
helmoet
Forum|alt.badge.img+8
  • August 24, 2016
Hi, I tried to implement @david_r solution into a Pythoncaller, sadly the resulting workspace won't run and complains about undefined macro %s. I needed the solution since I read a parameter set containing FME Parameter references and use one of them to pass to a FeatureReader (for windows paths) as a filename. If I pass one of the parameter file strings, it complains that it cannot find the file, all though the file verily exist..
  • August 24, 2016
Can you post the code here? Or even better, a workspace to reproduce the issue?
  • August 24, 2016
The helper functions @david_r presented have been added to the FME 2017.0 beta as:
fme.resolveFMEMacros(value) fme.getAbsolutePath(fileName)
Documentation can be found at http://docs.safe.com/fme/2017.0/html/FME_Desktop_Documentation/FME_Workbench/Configuration/FME_BEGIN_PYTHON.htm
This has been released as part of FME 2017.0 . Visit http://www.safe.com/downloads to download it and give it a spin.
paalped
Forum|alt.badge.img+5
  • November 13, 2017
I do it this way:
path = FME_MacroValues['your_param_containing_path'] if re.search('\\$\\(',path): _path = path.split('(')[1].split(')')[0] _path_rest = path.split(')')[1] path = os.path.join(FME_MacroValues[_path],_path_rest).replace('/','\\\\') Paal Pedersen
