Archived
Show FME Version in DataInspector Window Title
Related products:FME Form
mhab
It would be helpful and make my life with three different FME versions on the same machine easier if I could see in the DataInspector Window Title which version is running. It would also be consistent with workbench behaviour.
As ffs files are mostly incompatible between major FME versions I have to switch between DIs frequently.
