Archived
DI: transparent rendering option for 3D solids
Related products:FME Form
  • June 8, 2018
  • 12 views
mhab
As there seems to be no way in FME DataInspector to make 3D solids "partly" transparent, like area filling is now, I suggest to add a rendering option for 3D features which allows to see through solids.
I have quite hard times to inspect the parts of a solid when I need to always rotate it so that the marked vertex/point is in foreground.
It would help greatly if it would be possible to see through the surfaces. One application would be to investigate CityGML data
see also: Knowledge Center Discussion
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
LizAtSafe
Forum|alt.badge.img+15
  • February 10, 2024
Updated idea statusGathering InterestArchived
Idea merged into:
All the votes from this idea have been transferred.
