Archived
Add functionality in the Microstation DGNReader to import the 'Named Group' valu
Related products:Integrations
***Note from Migration:***
Original Title was: Add functionality in the Microstation DGNReader to import the 'Named Group' value
I have recently found out with the help of @danilo_fme (see post:
https://knowledge.safe.com/questions/71597/expose-group-element-in-microstation-dgn-v8-file.html?childToView=71710#comment-71710) that it is not possible to import the 'Named Group' value from a Microstation DGN file into FME. It would be great if the DGN Reader was modified to enable the import of this value as an attribute.
See attached a document describing the Microstation DGN 'Named Group' feature and also a screen grab of the Element ID properties dialog box with the 'Named Group' feature circled in red, within Microstation.
Thanks,
namedgroups.pdf
davideagle
Forum|alt.badge.img+21
  • July 2, 2018
Here's a doc that explicitly states that it's not supported but that page is more than 2 years since the last edit:
https://knowledge.safe.com/articles/1104/overview-of-microstation-design-format.html
Can I suggest you post a sample DGN with 'Named Groups' for the community to play with to see if there's any other options.
  • July 2, 2018
Thanks @1spatialdave I hadn't seen that overview before. I have attached a sample DGN.
Thanks,
grouping-copy.dgn
