Hi, If you want to configure HTTPS for your's FME Server with a PFX file.
Go to Configuration page and at the Tomcat configuration read and open the server.xml.
So you must add this parameter --> keystoreType="PKCS12" and modify this another parameters keystoreFile="<FMEServerDir>Utilities omcatyourfile.pfx" keystorePass="<your_password>"
Like This :
<Connector protocol="org.apache.coyote.http11.Http11NioProtocol"port="443" minSpareThreads="5" enableLookups="true" disableUploadTimeout="true" acceptCount="100" maxThreads="200" scheme="https" secure="true" SSLEnabled="true" keystoreFile="<FMEServerDir>Utilities omcatmyfile.pfx" keystorePass="PKCS12" keystorePass="<your_password>" clientAuth="false" sslEnabledProtocols="TLSv1,TLSv1.1,TLSv1.2" sslImplementationName="org.apache.tomcat.util.net.jsse.JSSEImplementation" ciphers="TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256,TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA,TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384,TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA,TLS_RSA_WITH_AES_128_GCM_SHA256,TLS_RSA_WITH_AES_256_GCM_SHA384,TLS_RSA_WITH_AES_128_CBC_SHA256,TLS_RSA_WITH_AES_256_CBC_SHA256,TLS_RSA_WITH_AES_128_CBC_SHA,TLS_RSA_WITH_AES_256_CBC_SHA,SSL_RSA_WITH_3DES_EDE_CBC_SHA"URIEncoding="UTF8" />
That's enough, continue the tutorial admin and restart FME SERVER and it's done
Bye Eric
