ReleasedFME 2023.0
Improvements to the DateTimeConverter
Related products:Transformers
  • September 13, 2018
  • 23 views
debbiatsafe
siennaatsafe
+7
  • debbiatsafe
    debbiatsafe
  • siennaatsafe
    siennaatsafe
  • david_r
  • ebygomm
  • takashi
  • danilo_fme
    danilo_fme
  • jelle
    jelle
  • cwarren
    cwarren
  • juha_inkila
  • ngairedutton
  • oxyat
  • mark2atsafe
    mark2atsafe
The old date time formatter allowed setting the attribute to a default value if it could not be converted. This was useful as it allowed you to set to a null value or dummy date. The datetimeformatter just passes all features with invalid dates out the rejected port, if formatting a number of attributes with dates there is no information as to which attribute has the invalid date.
Rejected features also seem to loose the original data - it would be helpful to retain these so that further work/ manipulation on the data could be done.
LizAtSafe
Forum|alt.badge.img+16
  • April 5, 2025
OpenReleased
LizAtSafe
  • April 5, 2025
In FME 2023 and newer using the latest version of the DateTimeConvertor should address a few of these: the rejection message should now indicate what attribute could not be converted and the original attribute values are maintained
