Open
Add the tolerance parameter for Spatial Filter
Related products:Transformers
  • November 8, 2018
  • 8 views
agelfert
philippeb
liamfez
  • agelfert
    agelfert
  • philippeb
    philippeb
  • liamfez
    liamfez
jelle
Is it possible to add the Tolerance parameter for the Spatial Filter as well? I have some issues with the 12th decimal number in an AutoCAD file. So, I was disappointed not to find this option for this Transformer.
erik_jan
Forum|alt.badge.img+18
  • November 8, 2018
Could get you the wrong results:
For example after applying a tolerance a point might be inside two separate polygons.
Not sure that is a good idea.
Surely not automatic, maybe as an option.
