Archived
Add the ability to smooth lines while keeping the original line vertices
  • siennaatsafe
    siennaatsafe
  • lianaolianov
fmelizard
  • July 13, 2018
So in other words - fit curves to the lines vertices.
btl
Forum|alt.badge.img+3
  • July 19, 2018
Yes, for example, when a line is drawn from GPS points this would be useful - the existing smoothing algorithms in the Generalizer tend to move the path of the line away from the original vertices to varying degrees.
  • March 4, 2019
For example smoothing lines drown from raster, specially when shape is similar to rectangle or have right angle
