Open
Facility to Enable and disable feature service editor tracking in AGOL Writers
Related products:Integrations
danilo_fme
boydfme
denniswilhelm
matthias_ct
  • danilo_fme
    danilo_fme
  • boydfme
    boydfme
  • denniswilhelm
    denniswilhelm
  • matthias_ct
    matthias_ct
I have noticed if you have editable layer and many peoples are working(and you have enabled edits tracking) then ArcGIS online puts username value in Editors Column .
Problem -
As a admin if you update data in that layer it will update username with your admin account (or account you are currently using) and it will remove existing username (in some cases people want to retain those values specially if data editing is outsourced to different company for billing purpose). So before editing admin need to disable Edit tracking manually in ArcGIS online.There are some other workarounds also to switch off and on (In my case I have used http caller and python). But it will we great if it includes in standard transformers , it will help to build clean workflow as well as easy to automate.
Thanks & regards
Manoj
Hello Manoj, I also have this issue with not wanting to update the last edit date and editor with my information and would benefit from a standard transformer. In the meantime, can you share more details about how you used the http caller and python. I haven't worked with either before. I have FME desktop 2018 and I am working with portal hosted feature services instead of online hosted feature services. I thinking that your process is similar enough that I can apply it.
Kind Regards,
Laura
Sorry, I haven't got any notification about your comment. You still need that?
Hello,
Thank you for your follow up. Yes, I am still looking for a solution.
Laura
Handling Editors tracking for GeoDatabase
Sure :).
To enable and disable GDB Editor tracking you need to modify below python script in workbench's scripting --> Startup Python Script
and you need to choose Pyhton Compatibility : Esri ArcGIS Pro 2.1+ (Python 3.6+)
Below piece of python will disable editor tracking in GeoDatabase
# Disable Editor Tracking
# Import system modules
import arcpy
from arcpy import env
# Set workspace
env.workspace = "Your GDB path"
# Set local variables
in_dataset = "Your table name"
# Disable editor tracking
arcpy.DisableEditorTracking_management(in_dataset)
Below piece of python will enable editor tracking in GeoDatabase
Shutdown Python Script
# Enable Editor Tracking
import arcpy
# Set workspace
# Enable editor tracking
arcpy.EnableEditorTracking_management(in_dataset,"created_user","created_date","last_edited_user","last_edited_date")
I am not able to attach example work bench for AGOL
I am not able to attach fme workbench. So I will provide a snapshot for enabling and disabling
Can you send me your email id so that I can forward demo workbench to you. I am not able to attach anything here.
@gangwarmanoj Can you please let me know how to determine what my email id is and I will forward that to you.
Laura
