Archived
Tester - restrict/warn for certain Operators and Comparison Mode
Related products:Transformers
siennaatsafe
nielsgerrits
jelle
  • siennaatsafe
    siennaatsafe
  • nielsgerrits
    nielsgerrits
  • ebygomm
  • jelle
    jelle
Currently the tester allows you to use a comparison mode of Case Sensitive/Case Insensitive with greater than and less than operators. There may be good valid reasons why someone would want to consider 111 to be less than 20 whilst also considering 20 to be greater than 199 but I'd hazard a guess that these use cases would be far more rare than someone wanting to do a numerical comparison and having the incorrect comparison mode selected. Currently the In Range operator is only available when the comparison mode is set numeric or automatic, but greater than and less than are not restricted in the same way.
Additionally, it means that if you send string characters to a greater than/less than test that is set to automatic the test is attempted when it might be preferable to produce an error.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
jdh
Forum|alt.badge.img+28
  • November 7, 2019
There are a couple of times where I want to know that 3B is greater than 2A.
Forum|alt.badge.img+39
  • November 7, 2019
Yes, ideally the option would still be available if needed, but somehow set up so that it was less likely to be used in error - i'm not sure what that looks like though
