Open
Notification FME Hub custom transformer upgrade
Related products:FME Form
danilo_fme
  • danilo_fme
    danilo_fme
taojunabc
Participant
You can add and download the FME Hub custom transformer by searching for keywords, as well as adding a general transformer, Once you have downloaded the custom transformer, FME will always use the downloaded local transformer. Even when the custom FME Hub transformer is upgraded, the user will not be notified of the upgrade.
I suggest that when you add a transformer that is downloaded from the FME Hub, If the FME Hub has an updated version, the upgrade prompt is displayed in the transformer brief.
kweller
Forum|alt.badge.img+8
  • March 8, 2018
There should also be a flag on any previously downloaded or linked FME Hub transformers so that one knows at a glance that an update is available. Then the update option should be available on the transformer's context menu, just as with local linked transformers.
Forum|alt.badge.img+34
  • June 4, 2020
It doesn't even appear to be straightforward to update a custom transformer even when you know the update exists
