Archived
ZIP empty folders with Filecopy on FME Server
Related products:FME Flow
  • siennaatsafe
    siennaatsafe
  • sigtill
    sigtill
  • henrikthoren
The Filecopy writer can be used to copy a folder structure and populate it with files. However sometimes the folder structure will contain empty folders that you want to copy because they will be polulated manually when you work on a project. This works on FME Workbench, but not when you move the workspace to FME Server.
