Gathering Interest
Make the Snapper and AnchoredSnapper Snap in 3D.
Related products:Transformers
  • October 29, 2015
  • 8 replies
  • 129 views
martin_ekstrand
couch
siennaatsafe
+61
  • tanguyg
  • martin_ekstrand
    martin_ekstrand
  • couch
    couch
  • hollyatsafe
  • siennaatsafe
    siennaatsafe
  • nathanatsafe
    nathanatsafe
  • fmelizard
    fmelizard
  • david_r
  • ebygomm
  • redgeographics
  • danilo_fme
    danilo_fme
  • erik_jan
    erik_jan
  • sigtill
    sigtill
  • tcrossman
    tcrossman
  • vxn43
    vxn43
  • bruceharold
    bruceharold
  • jelle
    jelle
  • kennyo
    kennyo
  • chriswilson
    chriswilson
  • lazarlubomir
    lazarlubomir
  • srg
    srg
  • aquamarine
  • olivier
    olivier
  • charry
    charry
  • koenterralytics
    koenterralytics
  • gbj1717
    gbj1717
  • mikael_sweco
    mikael_sweco
  • andrej
    andrej
  • marko
  • simonbea
    simonbea
  • rhartley
  • bou.spiering
  • mrtihon
  • pratsch
    pratsch
  • r5
    r5
  • t_hohenstrater
    t_hohenstrater
  • geolassi
    geolassi
  • vn1
    vn1
  • cwarren
    cwarren
  • jiranek_hsro
    jiranek_hsro
  • hsamor
    hsamor
  • kkrajewski
  • endest
    endest
  • gtihon
  • alexvsn
  • ekkischeffler
    ekkischeffler
  • geogaard
    geogaard
  • gabriel_hirsch
    gabriel_hirsch
  • zzupljanin
    zzupljanin
  • anari
    anari
  • venu
    venu
  • setld_solutions
    setld_solutions
  • bmdull
  • hansh
    hansh
  • kino
  • soeren
    soeren
  • iamjameselliott
  • t4
  • mikmansson
  • jeroenpeters
    jeroenpeters
  • asmundhg
  • mikis
  • sichenbim
  • arenscott
    arenscott
  • marius.hansen
    marius.hansen
  • moosi
    moosi
gabriel_hirsch
Make the Snapper snap in 3D.
nielsgerrits
Forum|alt.badge.img+54
@gabriel_hirsch And don't forget the AnchoredSnapper in 3D!
This would be of great benefit to the team that I work in as most of the datasets that we use are in 3D. One of our common tasks is to ensure our 3D lines are snapped but currently the method that we are using is long-winded and cumbersome and involves the following steps:
-breaking the lines down into their vertices
-extracting the XYZ values of the start/end vertices
-comparing the XYZ values of the start/end vertices of lines that are supposed to be joined together
-creating new vertices if the XYZ values differ
-joining the vertices up again to recreate the lines
A 3DSnapper and 3DAnchoredSnapper would allow us to do this in a much simpler and more efficient way.
  • April 5, 2017
This would significantly benefit organisations that use 3D network data especially in the transport and utilities sectors. In particular, large infrastructure projects in the UK, such as Crossrail and High Speed 2, would benefit from having a 3D Snapper and 3D Anchored Snapper.
r5
Forum|alt.badge.img+4
  • November 16, 2018
Snapper and AnchoredSnapper in 3D would be very helpful for the work I do. Also more clarity in the documentation for all spatial transformers as to weather they work in 3D.
Thanks!
It would be great if you could specify if the snapping tolerance should be treated in 2D of 3D.
E.g. (1,1,1) snaps tot (1,2,10) with a 2D snapping tolerance of 1 but not with a 3D snapping tolerance of 1.
A 2D tolerance is especially useful with the 3DAnchoredSnapper.
LizAtSafe
Forum|alt.badge.img+15
  • February 12, 2024
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • March 25, 2025
OpenGathering Interest
andreaatsafe
Forum|alt.badge.img+12
Hello! 👋
We’re looking for your input as we begin adding 3D support to the Snapper and AnchoredSnapper transformers!
From initial comments in this thread, we understand that 3D support primarily means including Z values alongside XY when snapping. But we want to make sure we fully understand how you expect this to work in practice.
💬 We’d love to hear from you:
  • What geometry types would you like to snap in 3D? (curves, areas, solids, etc)
  • What coordinate system would your data be using?
  • Are there any specific behaviours you expect 3D snapping to support — or avoid?
If you can share your use cases with a sample workflow or data — either in a comment below or via direct message — that would be incredibly helpful as we shape this project.
Thank you!
