Archived
The solution for Access token not found for connection ArcGIS online and FME SER
Related products:FME Flow
***Note from Migration:***
Original Title was: The solution for Access token not found for connection ArcGIS online and FME SERVER
Fix connection issue .FME SERVER
Connecting to ArcGIS Online via FME Server
The below video I have created to show the way how to fix this issue ,I did it and it's work with me
https://youtu.be/kWj-LdX-A8E
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
rylanatsafe
Forum|alt.badge.img+13
Hi @najedjamal! Thank you for your contribution to the Knowledge Center!
Please note that I will be marking this 'Idea' as Closed, as I believe that it represents a workflow issue and workaround rather than representing a request for a new feature in the FME Server product.
If you have any remaining questions or concerns regarding the AGOL access token and FME Server, please don't hesitate to reach out to our Support Team.
  • June 27, 2018
Hello Rylan
Thanks for your feedback , agree with you.
