Workbench failing
  • Aug 15, 2022 6:33 AM UTC
  • 56 views
deanhowell
Forum|alt.badge.img+24
I have a workbench that runs fine from the desktop but fails with lots of 'BADNEWS' messages (over 3500) before it crashes with the following statusMessage
FME Engine encountered an issue and will need to be restarted. [0] string too long [1] auto __thiscall STFDynamicFactory::process::<lambda_afd8337cf6d9dd4ee4340623b50e5675>::operator ()(void) const(c:\\code\\fme\\foundation\\pluginbuilder\\pluginbuilder_cpp\\dynafact.cpp:460) [2] auto __thiscall STFDynamicFactory::process::<lambda_afd8337cf6d9dd4ee4340623b50e5675>::operator ()(void) const(c:\\code\\fme\\foundation\\pluginbuilder\\pluginbuilder_cpp\\dynafact.cpp:460)
The workbench, attached, basically takes some input layers and creates a lot of reports.
Does anyone know why this might be occurring?
  • Aug 15, 2022 7:24 AM UTC
You'll probably want to contact your FME reseller or Safe support directly for this.
deanhowell
  • Aug 15, 2022 7:54 AM UTC
Thanks and will do​
