window authenticated users can't access FME Server UI
  • May 3, 2023 7:03 PM UTC
  • 0 replies
  • 95 views
aguan
Forum|alt.badge.img+11
Connect to our company LDAP service in the FME Server's Windows Authentication service with the Single Sign On enabled, bring an user from LDAP and assign the user the fmesuperuser or fmeadmin role. But the user gets this error when login with Windows Authentication "you are not authorized to use this web application". Did I miss anything in the configuration of this user?
