Why is the workspace field empty after hitting [apply] in dynamic workspace dialog?
worjak
Forum|alt.badge.img+3
When in automations you work with the dynamic workspace runner the workspace field blanks after hitting [apply]. It is annoying and confusing because some times the chosen parameter value is not forgotten and some time it is forgotten!? I believe this is a bug but have not seen any mentioning of this in here. So appologies if this is a known issue expected to be solved in next release!
Before [apply]:fme-flow-dyn-wspc-not-blank-Skærmbillede 2024-01-02 162333After [apply]:
fme-flow-dyn-wspc-blank-Skærmbillede 2024-01-02 162333
sanaeatsafe
Forum|alt.badge.img+7
Thanks for reporting this! I'm unable to reproduce the issue on my local FME Flow installation, so far. What FME Flow version and build are you using? OS? Thanks.
worjak
  • January 4, 2024
Thanks, here are our details:
FME Flow 2023.1.1.1
Build 23636 - win64
christian_dan
For me it also occurs in FME Flow 2023.2.1 (Build 23774 - win64)
