Why has the "Run" button disappeared from my Server Apps?
  • November 12, 2019
  • 32 views
billybob
For some reason my Server Apps no longer have a "Run" button when they are executed. See image below. All the Server Apps are executing workspaces that are in the same Repository. The only change that was made to the Repository was giving an additional user permission to access the Repository. The Server App tokens are all still viable. Any thoughts on how to recover?
Thanks,
Frank
Hi @billybob
Are you able to share a screenshot of the permissions that token has?
I'm wondering whether it has explicit run permission on that repository - you might to try setting that:
You might also want to check that the token has permission to run the workspace using the right service:
If that doesn't bring the run button back, can you post a screenshot of your token's current permissions. You could also try generating the app with a token that has full permissions to test to check that the run button appears.
billybob
  • November 12, 2019
Yes. That was it. I reset the token permissions for each of the Server App to "Read" and "Run". See image below. I'm not sure how they were changed, but resetting them did the trick.
Thanks for helping me out.
Regards,
Frank
