Trouble using webhook Payload
I am having issues with using the payload that is being sent to the webhook in FME server. I have setup a webhook, I watched this video: https://www.safe.com/webinars/hook-line-and-sinker-reeling-in-arcgis-webhooks/
But I cannot set the same values in my ParameterFetcher and my Workspace on FME server is not allowing me to set anything with webhook.
I have the webhook created and I am able to log the webhook message to the logs and see the expected output. I am having issues sending it into an fme workspace.
Best answer by hkingsbury
Is the parameter set at the workspace level?
If you look in the navigator you should see a list of parameters there. If there is nothing there (which I'm guessing there isn't as the box is red) then that won't pass through to the automation
hkingsbury
Forum|alt.badge.img+55
  • March 16, 2023
perfect thanks, found this :) http://imgscloudapps.com/Training/arcgis/1-Exercises/webhooktrigger/webhooktrigger/
