There was an error connecting to monitoring service
  • Mar 3, 2021 9:25 PM UTC
  • 5 replies
  • 228 views
dmerrick
I am trying to set up topic monitoring as per the Receiving email, Part 1: Setting up a topic and an email address, but when I turn on Topic Monitoring the error " There was an error connecting to monitoring service", inspecting the error in chrome shows that websocket connection failed "failed: Error in connection establishment:". The websocket 7078 port is not blocked by any firewalls.
Thanks!
hkingsbury
Forum|alt.badge.img+73
  • Mar 4, 2021 7:47 PM UTC
Are you using a reverse proxy in the middle (IIS)? You'll need to configure the correct routing parameters for the websocket ports
dmerrick
  • Mar 4, 2021 8:05 PM UTC
We are not using a reverse proxy.
  • Mar 9, 2021 5:50 PM UTC
Hi did you ever get a resolution for this ? I have the same issue ..
dmerrick
  • Mar 9, 2021 10:26 PM UTC
not yet, I am working on the issue with technical support with SAFE at the moment. I will let you know the outcome.
dmerrick
  • Mar 30, 2021 6:46 PM UTC
Hi @paulg​, after IT and SAFE provided much assistance, our current email set up does not work with the current FME websocket/email notification system.
The initial set up of the HTTPS set up (steps 14-17) were what was causing the initial issues https://community.safe.com/s/article/Using-a-CA-Certificate-with-FME-Server
