SMTP relay not installed with FME server 2017?
  • Mar 17, 2017 10:58 AM UTC
  • 8 replies
  • 106 views
jpvo
I am working on a classical installation of FME server 2017 and after running the post installation script (as admin) I can't see the FME Server SMTP relay service and I can't find the following file to configure the service:
<FME Server Install DIR>\\Utilities\\smtprelay\\james\\apps\\james\\SAR-INF\\config.xml
According to documentation I should have it at this time of installation.
Is there something new in FME 2017 or am I missing something in my installation?
@kenatsafe: I can't follow your documentation because I even don't have the service available.
Anyone having problem recieving email with FME server?
Thank you for your help.
.JP
Best answer by david_r
I don't think the SMTP relay service is a separate service in FME 2017, at least it wasn't installed on my machine either :-) I wonder if it's included in the Core now, try configuring a Publication of type "Email (SMTP)" and see if it works.
Hopefully @aaronkoning can chime in with details...
  • Mar 17, 2017 3:16 PM UTC
jpvo
  • Mar 17, 2017 3:33 PM UTC
The error message when I try to configure a publication is "Could not find publisher". It's sounds to me like the runPostInstall.bat did not worked properly. However, I can see the email publisher on the file system under "localization/publisher".
The log says: Unable to start email server: Path not found.
  • Mar 17, 2017 3:37 PM UTC
Strange, sounds like a case for Safe support.
jpvo
  • Mar 17, 2017 3:44 PM UTC
I sent an email. We'll see next week. I'll post the answer when I'll have it.
fmelizard
Forum|alt.badge.img+22
  • Mar 17, 2017 6:32 PM UTC
You are correct. The FME Server Core now handles inbound SMTP.
fmelizard
  • Mar 17, 2017 6:38 PM UTC
Also, I've updated the article to indicate parts specific to 2016 and previous:
https://knowledge.safe.com/articles/427/fme-server-smtp-relay-service-fails-to-start.html
allisonhughes
@aaronkoning, just a heads up that the batch file for Restart FME Server still tries to stop and start the SMTP service and gives a "service name invalid" error in the command line. It's not really a problem but it would be good to clean up for the next version :)
  • Aug 19, 2019 7:02 PM UTC
Are there any config files associated with FME core for smtp and if so where can they be found?
