Sentinel-2 on AWS returns Cannot find Query_Options.Band_List error
  • Mar 30, 2017 7:30 AM UTC
  • 7 replies
  • 80 views
zzupljanin
Forum|alt.badge.img+5
basically I can't get any data (even preview) with this reader. I defined utm zones for my region and always get this error:
SENTINEL2 reader: Cannot find Query_Options.Band_List
What to do? Where to define this query?
jdh
Forum|alt.badge.img+41
  • Mar 30, 2017 2:29 PM UTC
Can you post a screenshot of your reader parameter settings?
itay
Forum|alt.badge.img+19
  • Mar 30, 2017 2:37 PM UTC
Are you using the options provided by the reader for the settings ? or typing them yourself?
stewartatsafe
Forum|alt.badge.img+10
I think we might have an issue. I am seeing that error too. I will look into it and get back to you.
stewartatsafe
I have confirmed this was an issue but it has been fixed. There was a change of format that wasn't supported by the underlying GDAL library in FME. You will need to download FME 2017.1 to get the fix.
fmelizard
Forum|alt.badge.img+22
  • Mar 31, 2017 12:08 AM UTC
As an alternative to @stewartharper's if you're not to keen to try out the beta. If you specify a date range in the reader that is no later than August or July of 2016 it should read in these OK. The format of the service changed around then.
zzupljanin
  • Mar 31, 2017 1:14 PM UTC
Thank you for your answers. Looking forward to check this in FME 2017.1
Cheers
zzupljanin
  • Apr 3, 2017 7:43 AM UTC
Unfortunatelly for my area even that doesn't work.
