Running the FME Server System Services
  • Feb 19, 2018 8:41 AM UTC
  • 46 views
arekpierchala
Hi
I want to use FME Server to work with data from Database (DB1) and Fileshare (FS1) and transform them and place in Database (DB2) and Fileshare (FS2). All Source and Destination resources are located on different, separate machine. Do I need to run FME Server services (FME Serv App Server, FME Serv Core, FME Serv Database, FME Serv Engines) on such user account which has an access to all resources DB1, FS1, DB2 and FS2?
Best answer by david_r
You only need to configure the Engine service to run as a domain user with access to the file shares:
http://docs.safe.com/fme/2017.1/html/FME_Server_Documentation/Content/AdminGuide/Running_FME_Server_Engines_Under_Different_Account.htm
  • Feb 19, 2018 8:48 AM UTC
