Repository "xxxxxxxx" doesn't exist or you do not have permission to Read or Run from it
  • Jun 16, 2022 1:31 PM UTC
  • 80 views
If i want to run apps from galery, system send me
But permissions on repository "xxxxxxxx" is OK - Run and Read.
This problem started after i tested changes in permissions on this repositories.
Versions: FME Server 2022.0.0.2 Build 22343 - win64
Thank you for your advices
richardatsafe
Forum|alt.badge.img+11
Hi @radek.cervenka​ ,
It should just be the token permissions for the workspace app that are required for the repository. Potentially you can make sure the token is still enabled and that it has run workspace and the app permissions in addition to the repository permissions.
