My workspace works on FME Desktop, but not on FME Server
  • Nov 11, 2016 6:34 PM UTC
  • 168 views
fmelizard
Forum|alt.badge.img+22
I have a workspace running great on FME Desktop. When I run it from FME Server, it doesn't work. What gives?
fmelizard
  • Nov 11, 2016 6:41 PM UTC
This can happen for a number of reasons. In these cases we have a pretty standard routine to work towards resolution.
1. Search the Knowledge Center for any information related to the problem.
2. Review the FME Server Troubleshooting Guide section called:
Are you having problems running a job using your own workspace?
3. Narrow down the problem using Debugging Guide for FME Server. Generally you will get to a point where you remove something and then the workspace starts to work. The last thing you removed is involved in the problem. So, then you remove/modify something in that thing and so on until you narrow it down to something that can be resolved.
erik_jan
Forum|alt.badge.img+26
  • Nov 11, 2016 6:42 PM UTC
The first thing to have a good look at is the availability of the data for the Readers. The data might be availble on the desktop, but not on the server.
fmelizard
  • Nov 11, 2016 6:56 PM UTC
Here is an example of this type of problem and one approach to narrow it down.
The workspace runs on FME Desktop, but not FME Server. Here are some of the variables in this example:
  • Separate machine
  • Account running the FME process (FME Engine service)
  • FME Workspace
  • PythonCaller Script
  • Python calls .vbs script
  • .vbs script
  • UNC path to .vbs script
---One way to narrow this down would be the following testing:
  1. Is UNC the problem?
    Place the .vbs file on the same machine as FME Server. Try it. Did it work?
  2. Is the content of the .vbs the problem?
    Create a testing .vbs script with a single command (e.g. print statement or variable assignment). Try it. Did it work?
  3. Does .vbs not work on the machine where FME Server is installed?
    Try running a .vbs script without using FME. Did it work?
  4. Does python with .vbs not work on the machine?
    Try running using python to run a .vbs script without using FME. Did it work?
These are the main tests I would do. I suspect permissions problems related to the Windows Service LogOn users running FME Server Engines.
