Looking for a tutorial to assist creating a simple web form to capture a-spatial information and push (append) it into a basic excel table
  • Sep 26, 2021 2:04 AM UTC
  • 164 views
benvk
Forum|alt.badge.img+8
Hey,
I am competent with FME Desktop, but an extreme novice to FME Server.
I understand with FME server we can create web-apps and the like, and I have a great entry level task I want to see if FME can assist with.
Currently we are emailed information from people within our organisation and we have to manually move this data into an excel spreadsheet.
I believe with FME Server it can host a page where these fellow staff can input a few basic text items (nothing spatial at this point, that will be phase 2 of my project) and then append it to a local excel table.
I am looking for a tutorial to assist me with this process. I am a little overwhelmed as all tutorials I have found so far are wanting the user to upload a file, and the server converts to another file and is returned. This is not really applicable with my basic phase 1 task.
Has anyone seen something that may assist, that is targeted to n00bs?
Kind regards,
Ben
itsmatt
Forum|alt.badge.img+48
  • Sep 26, 2021 10:46 AM UTC
With FME Server it's pretty easy to create a web app. When you try to run a published workspace on ​FME Server the published parameters will automatically be available and this is the same for the web app.
Here is a webinar from a year ago about it which should at least step you through the process:
https://www.safe.com/webinars/creating-no-code-web-apps-with-fme-server/
And here is a tutorial:
​https://community.safe.com/s/article/fme-server-apps
One think to keep in mind is the permissions, as in who can run the workspace? You will need to either create a login for each person who needs to use it OR make the app open to everyone. ​
Good luck!​
benvk
  • Sep 26, 2021 11:56 AM UTC
Ok very cool, I now have a web app that will take a name and an age, and will save to an excel doc.
To take this to the next level I would love to include a geometry picker, and have the user pick a point location, and have the lat and long captured in two different columns...
The tutorial/video provided skips over the setup of this, and just references that this can happen.
Any detail on what I could search for this config?
itsmatt
  • Sep 27, 2021 8:04 AM UTC
Nice one,
I think this should help:
https://community.safe.com/s/article/using-the-geometry-picker-in-fme-server
A special 'Geometry' type published parameter is required - You can then use a GeometryReplacer in your workspace to extract the geometry (GeoJSON format) as a point. One you have the point a simple CoordinateExtractor should give you the lat and long.
The 'Geometry' type published parameter is pretty neat because you can use a bonding box and also specify the geometry type required.
