List Cancelled/Failed jobs - VIA Rest API
  • Mar 12, 2018 3:12 PM UTC
  • 5 replies
  • 162 views
Is there a way to extract a JSON list of the jobs that have been canceled or failed? I can only really see a list for jobs that are either queued, running or completed? Ideally this would be great if this could be accessed via the REST API
  • Mar 12, 2018 3:29 PM UTC
I believe you'll have to do that in two stages:
First get all the job IDs of all completed jobs:
GET /transformations/jobs/completed
Then loop over all the completed jobs to get the job status for each job id:
GET /transformations/jobs/id/<jobid>/result
Hi @ryanslevin0,
In FME Server 2018.0 you can list all failed or succeeded jobs with a single call using the completedState query parameter:
GET /transformations/jobs/completed?completedState=failed
GET /transformations/jobs/completed?completedState=success
@david_r's solution is correct for all older versions of FME Server using the REST API v3.
  • Mar 12, 2018 4:47 PM UTC
Hi @ryanslevin0,
That's a great improvement!
Hi @ryanslevin0,
Thanks Gerhard, unfortunatly wer are using FME Server 2017 (though still using REST API v3), so using the URL doesnt seem to be making much difference
Is there a way to flag if the job has been Cancelled? We have a few jobs that are force canceled if they run to long, it seems there isnt anyway to flag a Cancelled job, only if its Failed or Completed...
  • Mar 13, 2018 7:41 AM UTC
In FME 2017 you can check if a job was cancelled by testing for status = 'ABORTED' in the response after calling the job status request, see my post below.
See also the documentation.
